Normal Topic BoxModifying event not firing (Read 2191 times)
jstraylor
Jan 2nd, 2007 at 4:39pm
Good day,
I am having a problem with the BoxModifying event not firing when I am moving a box.  I select the box via code and set the handlestyle to EasyMove.  I get the BoxModified when the mouse is released, but I do not get the Modifying event as the box is being moved.
Any suggestions??
Jeff
Re: BoxModifying event not firing
Reply #1 - Jan 3rd, 2007 at 6:27am
Good day,
Is the box in a multiple-selection? If there are more than one selected boxes, the control will raise SelectionMoving instead of BoxMoving.
jstraylor
Reply #2 - Jan 3rd, 2007 at 10:19am
Good Morning,
No, it is not part of a multiple selection, I have also turned AllowMultiSel to False.
In examining the Selection property of the flowchart I can see that the Arrows collection has a count of 1, and the Boxes collection has a count of 1.  I now think that I know where the problem is, I need to turn the SelectAfterCreate off on the flowchart to avoid the previous item from staying selected.
If that doesn't work, I'll just use the SelectionMoving event.
BTW, BoxMoving??  I didn't see that in the documentation.  I'm using BoxModifying.
Thanks for the help,
Jeff
Reply #3 - Jan 3rd, 2007 at 1:31pm
Use the Selection.Change() method to select the box and automatically deselect the arrow. Otherwise, if there are two items selected, the control will raise only the SelectionMoving event.
Indeed the box event name is BoxModifying.
