Normal Topic Error installing XML Viewer 3 (Read 7485 times)
garryc
Mar 4th, 2007 at 1:06am
Cannot install the Viewer in WinXP SP2 with all MS Updates applied, including MSXML 4.0 SP2 Security Update (KB927978 ). The install file, XmlViewer.msi, dated 05/12/13, was located on the C: disk for the install.
The following error occurs each time installation is attempted:
I was unable to find any assistance in Help and Support, online or otherwise, as the above error message suggests.
Does anyone have an idea what this error might mean?
Re: Error installing XML Viewer 3
Reply #1 - Mar 5th, 2007 at 8:55am
Here you can download a ready to use executable of XML Viewer 3.1, you need only to unzip it:
https://mindfusion.org/XMLViewer3.zip
domin8guy
Reply #2 - Feb 24th, 2009 at 3:24pm
This link does not work.
Reply #3 - Feb 25th, 2009 at 8:51am
