Normal Topic Dimensions of visible chart (Read 4908 times)
ymoran00
Jun 14th, 2007 at 6:19am
Is there a way to know the dimensions of the visible chart? When I use getBounds I get the entire chart.
I need it to find the coordinates of the center point on the screen.
thanks,
Yoav
Re: Dimensions of visible chart
Reply #1 - Jun 14th, 2007 at 6:41am
Try flowchart.getVisibleRect(), or flowchart.deviceToDoc(flowchart.getVisibleRect()) if you need it in document coordinates.
ymoran00
Reply #2 - Jun 14th, 2007 at 6:53am
I forgot about this method.
Thanks!
Yoav
ymoran00
Reply #3 - Jun 14th, 2007 at 7:01am
When I run chart.getVisibleRect(), I get this dimension:
0,2304,893,551
What does y=2304 mean?
Thanks!
Reply #4 - Jun 14th, 2007 at 7:05am
I guess that could happen if the flowchart is inside a JScrollPane and you have scrolled down a bit.
ymoran00
Reply #5 - Jun 14th, 2007 at 7:07am
Ah, ofcourse.
Embarrassed
silly me.
8)
Thank again.
Yoav
