Normal Topic Make node deselect when mouse dragged on dgmView? (Read 2055 times)
consolejoker
Dec 31st, 2007 at 4:04am
I have a situation where I select a node, then if I drag on the diagram view and never intersect with any other node, for instance just drag blank area, the selected node remains selected.
Any way to have it deselect?
It seems I can do this if I simply click outside the node, but dragging doesn't do it.
Re: Make node deselect when mouse dragged on dgmVi
Reply #1 - Jan 1st, 2008 at 5:36am
The selection changes only if the selection rectangle contains some items. You could handle the view's MouseUp event, check if (diagram.Interaction.CurrentItem is Selection), and if the Selection.Bounds does not contains any nodes, call Selection.Clear().
consolejoker
Reply #2 - Jan 1st, 2008 at 3:21pm
Is there an easy way to check if the selection bounds intersects any nodes or do I have to check it against all the nodes on the diagram?
Thx.
Reply #3 - Jan 2nd, 2008 at 6:41am
You will have to call RectangleF.IntersectsWith(selection.Bounds, node.Bounds) for each node in the diagram.
