Normal Topic Visio "Custom Properties" for Flow Chart (Read 6052 times)
JCRonSaratoga
Go Cubs Go!
Apr 16th, 2008 at 3:16pm
Hi
Using the MindFusion components, is it possible to access the "Custom Properties" information for a Visio Flow Chart shape?  I have a simple flow chart, with a custom property label called "Shape#" for the first flow chart element it has a value of "1", for the second flow chart element it has a value of "2", etc.  I want to display the visio flow chart (via the Visio .vdx file) then change the color of the Shapes.
If this is not possible, do you have any suggestions as to how I can dynamically change the Visio Flow Chart shapes.
Jim
Re: Visio "Custom Properties" for Flow C
Reply #1 - Apr 16th, 2008 at 3:34pm
If that will help, we can add an XmlElement argument to the NodeImported event - you could use it to find the XML DOM elements for the custom properties, and any other information related to the shape that is not imported automatically.
JCRonSaratoga
Go Cubs Go!
Reply #2 - Apr 16th, 2008 at 3:39pm
Whoa!  That would be sweet!
If I understand you correct, that is.  I see in Visio I can add "Custom Properties" and given them values.  Is what you are saying that I can then access those?  If so SWEET!!  Then when do you see being able to do this?
Jim
Reply #3 - Apr 16th, 2008 at 3:54pm
8) We'll try to add it for the version 5.1 release - we'll start beta tests for it in about a week.
JCRonSaratoga
Go Cubs Go!
Reply #4 - Apr 16th, 2008 at 3:57pm
Can I get access to the beta?
Jim
Reply #5 - Apr 17th, 2008 at 7:20am
Yes, I'll post the download link here when the beta is available.
Reply #6 - Apr 18th, 2008 at 8:33am
This version of the VisioImporter adds a ShapeXml argument to the ShapeImported event:
https://mindfusion.eu/_beta/fcnet51_visioxml.zip
Assuming you have added a custom property called "MyProperty", you can get its value like this:
private void ShapeImported(object sender, ShapeImportedEventArgs e)
	XmlNode vdxCode = e.ShapeXml;
	try
		XmlNamespaceManager ns = new XmlNamespaceManager(e.ShapeXml.OwnerDocument.NameTable);
		ns.AddNamespace("vdx", "http://schemas.microsoft.com/visio/2003/core");
		XmlNode myPropVal = vdxCode.SelectSingleNode("vdx:Prop[vdx:Label='MyProperty']/vdx:Value", ns);
		if (myPropVal != null)
			e.Shape.Tag = myPropVal.InnerText;
	catch (Exception ex)
		MessageBox.Show(ex.Message);
I don't know if all Visio shapes save the custom properties in that format. If that XPath doesn't work for you, look in the VDX file to see where exactly the property is saved for the shapes you are using.
JCRonSaratoga
Go Cubs Go!
Reply #7 - Apr 21st, 2008 at 4:59pm
Thank you for the coding,  I converted it to VB.Net 2008.   Can you please send me how to call that subroutine?  Here is what I have tried, but it is not working:
    Private Sub btnImport_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnImport.Click
       Dim ofd As New OpenFileDialog
       If ofd.ShowDialog() = DialogResult.OK Then
           Dim imp As New VisioImporter
           imp.ImportAllPages(ofd.FileName, diag)
           Dim AAA As MindFusion.Diagramming.Import.ShapeImportedEventArgs
           Call ShapeImported(sender, AAA)
       End If
    End Sub
Reply #8 - Apr 21st, 2008 at 5:25pm
That's a handler for the importer's ShapeImported event. In VB.NET, you should attach it like this -
AddHandler imp.ShapeImported, AddressOf ShapeImported
before calling the ImportAllPages method.
JCRonSaratoga
Go Cubs Go!
Reply #9 - Apr 21st, 2008 at 8:22pm
Excellent!  Thank you, that works well!
