Normal Topic Serializing Cut/Copy and File Save (Read 3052 times)
maui26
May 13th, 2008 at 8:08pm
I am currently evaluating the trial version.
I am getting the same following error when using CopyToClipboard, CutToClipboard, and SaveToFile:
Type 'Designer.SerializableDictionary`2[[System.Int32, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[Designer.PropertyValue, Designer, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null]]' in Assembly 'Designer, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' is not marked as serializable.
I have no problems with importing/exporting XML using LoadFromXml and SaveToXML after handling the DeserializeTag and SerializeTag events. (see posting http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=119616009...) - My ShapeNode tag objects are set to a serializable object that contains a SerializableDictionary object with a value that's a serializable object... - in otherwords, all my custom objects should be serializable.
I realize that I need to write a handler for SerializeControl and DeserializeControl, but do not know how to proceed. Could you please advise?
Re: Serializing Cut/Copy and File Save
Reply #1 - May 14th, 2008 at 7:15am
Apart from implementing ISerializable, you should mark the tag classes with the [Serializabe] attribute. Have you done that?
maui26
Reply #2 - May 14th, 2008 at 1:20pm
I guess the class I'm using is a bit out of the norm for serialization. In .NET the Dictionary class is not serializable, so I ended up creating an SerializableDictionary class that implements the IXMLSerializable interface (here's where I got the code:
http://weblogs.asp.net/pwelter34/archive/2006/05/03/444961.aspx )  In this case, I did not need to mark my class with [Serializable()].
But I took your advice and went ahead and added the [Serializable()] marking to the SerializableDictionary class:
[XmlRoot("dictionary")]
[Serializable()]
    public class SerializableDictionary<TKey, TValue>
       : Dictionary<TKey, TValue>, IXmlSerializable
and the result was this error:
Type 'MindFusion.Diagramming.Shape' in Assembly 'MindFusion.Diagramming, Version=5.0.3.20676, Culture=neutral, PublicKeyToken=a0d18338041985ba' is not marked as serializable.
It's definitely that Dictionary object that's making all the trouble. I'm thinking I might need to use another lookup/hash object to implement my logic.
Thanks for the quick response!
Reply #3 - May 14th, 2008 at 1:53pm
The Hashtable class is serializable, however it still won't work if you are storing Shape objects in the table, since we haven't marked the Shape class as serializable. It should be fine if you save Shape.Ids there instead of Shapes, and later use the Shape.FromId() method to get the corresponding shape.
maui26
Reply #4 - May 14th, 2008 at 5:38pm
I just ended up writing my own event handlers to cut/copy/paste on selected ShapeNodes in the diagram.
Thanks!
