Normal Topic AllowInplaceCreate help (Read 2279 times)
bpeacock
War Eagle!
Aug 13th, 2008 at 1:47pm
I am trying to enable Inplace create so our users can click on the calendar and start typing to create a new appointment.  In design mode, I have AllowInplaceCreate = true
AllowInplaceEdit = true
When we initialize\load the calendar I set
AllowInplaceEdit = false
This is the way our sample application is set and works fine.  Is this something else I need to set for this to work?  I seem to be missing something while comparing the two apps.
Re: AllowInplaceCreate help
Reply #1 - Aug 13th, 2008 at 2:04pm
In-place editing and creation are both enabled by default, therefore there is no need for you to set anything in order to enable them.
"I seem to be missing something while comparing the two apps."
I am not sure which two apps you are referring to. Can you be more specific?
bpeacock
War Eagle!
Reply #2 - Aug 13th, 2008 at 2:35pm
I am referring to the app I am trying to get this working in and the sample app this seems to be working in.
Reply #3 - Aug 14th, 2008 at 7:27am
The following code should enable users to create new items interactively, but prevent them from editing existing items:
calendar.AllowInplaceCreate = true;
calendar.AllowInplaceEdit = false;
If that is what is happening at your side, then everything is set up appropriately.
