Hot Topic (More than 10 Replies) Container Node (Read 6136 times)
muthuhamid
Container Node
Jul 9th, 2009 at 12:44pm
Hi
I have diagram with few container nodes and each container node has some shape nodes with unique id property. when user pick one shape node from one container (for exampe uniqueid=1) to the another container node which has the same unique id 1 already, i should not allow to drop into that container and return it back to its original container node. and if that shape node with same unique id is not exist then ill allow user to drop into the second container.
How can i do this?
Re: Container Node
Reply #1 - Jul 9th, 2009 at 2:47pm
Handle NodeModifying, and if GetNodeAt(mousePosition) returns a container with the same id, set e.Cancel = true.
muthuhamid
Re: Container Node
Reply #2 - Jul 9th, 2009 at 3:39pm
Yes perfectly it works fine and now i have another Question related to container node. i use the custom class which you gave me before for rounded corder container node. in which am trying to add an image as background for that container , please gothru the coding that am using image object and Texturebrush to implement this features, but what am getting is the image is tiled one after another in the container instead of stretching to the size of the container node.
Public Overloads Overrides Sub Draw(ByVal graphics As MindFusion.Drawing.IGraphics, ByVal options As RenderOptions)
If Not ShouldRender() Then
Exit Sub
End If
Dim brushBounds As Rect = GetBounds()
Dim fillBrush As Brush = IIf(options.EnableInterior, Brush.CreateGdiBrush(brushBounds, -brushBounds.X, -brushBounds.Y), New SolidBrush(Color.FromArgb(0, 255, 255, 255)))
'Dim img As Image = frmConfirm_EMP_INS_Allocation.imgContainers.Images(imageIndex)
'Dim fBrush As New System.Drawing.TextureBrush(img)
'Dim fillBrush As Brush = IIf(options.EnableBackgroundImage, fBrush, Brush.CreateGdiBrush(brushBounds, -brushBounds.X, -brushBounds.Y))
Dim borderPen As Pen = Pen.CreateGdiPen()
' draw the container frame
Dim rect As Rect = GetBounds()
Dim roundRect As GraphicsPath = InternalUtils.GetRoundRect(rect.X, rect.Y, rect.Width, rect.Height, 3)
graphics.FillPath(fillBrush, roundRect)
graphics.DrawPath(borderPen, roundRect)
roundRect.Dispose()
If CaptionHeight > 0 Then
' draw the caption
If options.Scale > 1 AndAlso Caption.Length > 0 AndAlso options.EnableText Then
' create a hyperlink
Dim setLink As Boolean = Not String.IsNullOrEmpty(HyperLink) AndAlso options.HyperLinkStyle <> HyperLinkStyle.None
If setLink Then
graphics.BeginHyperLink(HyperLink, options.HyperLinkTarget)
End If
' draw the caption text
Dim captionBrush As Brush = New SolidBrush(CaptionColor)
graphics.DrawString(Caption, Font, captionBrush, GetCaptionRect(), CaptionFormat)
captionBrush.Dispose()
' close the hyperlink tag
If setLink Then
graphics.EndHyperLink()
End If
End If
' Draw the caption divider line
If rect.Top + CaptionHeight < rect.Bottom Then
graphics.DrawLine(borderPen, New Point(rect.Left, rect.Top + CaptionHeight), New Point(rect.Right, rect.Top + CaptionHeight))
End If
End If
' Draw the fold button
DrawManipulators(graphics, False)
' Cleanup
borderPen.Dispose()
fillBrush.Dispose()
End Sub
muthuhamid
Re: Container Node
Reply #3 - Jul 9th, 2009 at 3:46pm
I commented those texture brush image lines in the pervious post and also the images are not very clear seen it looks like dark blue area in the image.
here am pasting the 3lines of code without comment.
Re: Container Node
Reply #4 - Jul 10th, 2009 at 6:46am
Is there any reason for not drawing the image directly to the target graphics? As in replacing the FillPath line in your code with the following:
graphics.DrawImage(img, rect)
You also might want to set a clip before drawing the image to avoid drawing outside of the rounded corners.
muthuhamid
Re: Container Node
Reply #5 - Jul 10th, 2009 at 12:10pm
Thank you.
Actually what i need to do is i have container controls in my diagram view some of the the container ill be having image attached as a bacground, now as you said i draw the image to graphics directly but the broblem is if the user resize the container the image is not resizing to the container size it remains the same size.
Secondly some containers i dont need to attache images where as i use rounded corner with some gradient coloring within the container. for these two type of Containers now am using two different user classes that inherits the container class.
Could you pls help to resolve the class using image that is not resizing to its container size.
Re: Container Node
Reply #6 - Jul 10th, 2009 at 12:54pm
Are you using the Graphics.DrawImage method to render the background of the container? I am using this method and the results are as expected - the image always stretches to fill the bounds of its container.
muthuhamid
Re: Container Node
Reply #7 - Jul 10th, 2009 at 1:21pm
Yes i am using Graphics.DrawImage method here is the entire class
Imports System.Drawing
Imports MindFusion
Imports MindFusion.Diagramming
Imports Point = System.Drawing.PointF
Imports Rect = System.Drawing.RectangleF
Imports System.Drawing.Drawing2D
Public Class TrashAdapter
Inherits ContainerNode
Public imageIndex As Integer = -1
Exit Sub
End If
Dim img As Image = frmFinalResourceAllocation.imgContainers.Images(imageIndex)
graphics.DrawImage(img, New PointF(rect.X - 5, rect.Y - 10))
roundRect.Dispose()
' draw the caption
If setLink Then
End If
If setLink Then
End If
End If
End If
End If
' Cleanup
borderPen.Dispose()
End Sub
Public Overloads Overrides Sub DrawShadow(ByVal graphics As MindFusion.Drawing.IGraphics, ByVal options As RenderOptions)
Exit Sub
End If
Dim fillBrush As Brush = New SolidBrush(ShadowColor)
roundRect.Dispose()
fillBrush.Dispose()
End Sub
''' <summary>
''' Calculates the caption rectangle, excluding the fold
''' button if the container is foldable.
''' </summary>
Private Function GetCaptionRect() As Rect
Dim rect As Rect = Utilities.NormalizeRect(Bounds)
rect.Height = CaptionHeight
If Foldable Then
rect.Width -= CaptionHeight
End If
Return rect
End Function
End Class
Re: Container Node
Reply #8 - Jul 10th, 2009 at 1:56pm
Replace the line:
with the line:
graphics.DrawImage(img, rect.X, rect.Y, rect.Width, rect.Height)
The first line draws the image in its original size disregarding the size of the container.
muthuhamid
Re: Container Node
Reply #9 - Jul 10th, 2009 at 2:56pm
Thanks it perfectly working and i have another problem that the image i am using is not able to see as its original color, what i can see is a darkblue(navy) color filled in the image.
what should i do to see the actual image color.
Re: Container Node
Reply #10 - Jul 10th, 2009 at 3:10pm
Can you e-mail the image to me (meppy@mindfusion.eu) so that I can test what might be wrong with it?
muthuhamid
Re: Container Node
Reply #11 - Jul 10th, 2009 at 3:39pm
yes i sent now
muthuhamid
Re: Container Node
Reply #12 - Jul 10th, 2009 at 5:59pm
Hi meppy
is there a way to arrange the shapenodes of the container to fit (attached nodes is not fitting inside by default) within the container node.
For example i have shape node of user and his name as attached node at the bottom, here the name(text) the bottom of the user node is (visible to) outside of the container node.
How can i fix this?
Re: Container Node
Reply #13 - Jul 13th, 2009 at 11:22am
Try setting the FollowMasterContainment property on all subordinate items to true.
Re: Container Node
Reply #14 - Jul 14th, 2009 at 7:39am
After attaching the items to their master node, set masterNode.SubordinateGroup.FollowMasterContainment = true.
