Normal Topic UndoManager (Read 1399 times)
mberger
UndoManager
Oct 19th, 2009 at 2:00pm
i have some problems with the UndoManager in my Diagram. In my application i create and add nodes depending on some diagramevents.
Is it possible to access the CommandList in the undomanger history and delete some commands?
greeze Marco
Re: UndoManager
Reply #1 - Oct 19th, 2009 at 2:24pm
You could handle the Diagram.ActionRecording event and set e.Cancel = true to prevent some action being recorded.
mberger
Re: UndoManager
Reply #2 - Oct 19th, 2009 at 2:51pm
Hi Stoyo,
i know that i could filter the rcorded commands with this event. The Problem is, that i create and add nodes depending on some diagramevents. For example:
1. mouseclick
create OriginNode, create DestinationNode and create DiagramLink
2. mouseclick
old DestinationNode = new OriginNode, create new DestinationNode, create new DiagramLink
and so on..., until i cancel the chaincreation of the notes by rightclick.
The rightclick deletes the new DestinationNode and the DiagramLink.
i have tried to create a composite command with the delet command of the DetinationNode and DiagramLink and create a composite command of this two delete commands. After this i tried to filter the created composite command and cancel the recording.
This works fine, but now i have some problems if i try to undo the previously action.
... sorry for my realy poor english  Cheesy
greeze Marco
Re: UndoManager
Reply #3 - Oct 19th, 2009 at 6:57pm
Hi Marco,
Do you need the creation of this whole chain of nodes to be saved as a single composite command?
