Normal Topic Modifcationeffect=MoveShades display hidden links (Read 2622 times)
priyanka
Oct 29th, 2009 at 9:02am
With reference to the post: http://mindfusion.eu/Forum/YaBB.pl?board=wpfdg_disc;action=display;num=123830524...
I had set the diagram.ModificationEffect = ModificationEffect.MoveShades;
I had done the Visibility of all the outgoing and incoming links to a node to Collapsed.
But if the ModificationEffect property is set to MoveShades and when I try to move the node(whose links are made invisible) then the links connected to it are  visible while we drag the node from one place to other.
How could I make the links Visibility to Collapsed while I am moving the node.
Please provide some inputs.
Priyanka
Re: Modifcationeffect=MoveShades display hidden li
Reply #1 - Oct 29th, 2009 at 11:27am
This version doesn't display the collapsed links:
https://mindfusion.eu/_beta/wpfdiag_shadesvisb.zip
priyanka
Reply #2 - Oct 29th, 2009 at 11:52am
Thanks Stoyo,
But are these dll's not available with the latest version..???
Priyanka
Reply #3 - Oct 29th, 2009 at 1:49pm
We'll release this fix with an official version next month.
priyanka
Reply #4 - Oct 29th, 2009 at 1:50pm
Thanks Stoyo,
Priyanka
