Normal Topic Custom shape and SaveToString issue (Read 2591 times)
Mas-Tool
Mar 20th, 2010 at 8:40pm
I'm making a custom node shape with the following code:
ShapeNode recStart = diagram.Factory.CreateShapeNode(new Rect(0,0,130,52));
recStart.Shape = new MindFusion.Diagramming.Wpf.Shape(
new ElementTemplate[]
new LineTemplate(0, 100, 50, 74),
new LineTemplate(50, 74, 100, 100),
new LineTemplate(100, 100, 100, 0),
new LineTemplate(100, 0, 50, 0),
new LineTemplate(50, 0, 0, 0),
new LineTemplate(0, 0, 0, 100)
}, null, FillRule.Nonzero);
but it seems that when i use the SaveToString and LoadToString the custom shape is gone, and i get a normal rectangle.
Anything i can do to solve this ?
Thanks in advance,
Miky.
Re: Custom shape and SaveToString issue
Reply #1 - Mar 21st, 2010 at 7:14am
Hi Miky,
At this time the shapes of nodes are saved only by their IDs. You can specify an ID through the Shape constructor. Also move the shape definition code to the app's startup / initialization method, so that the Shape definition is available before calling LoadFromString.
If you need more custom shapes, you could save them in a shape library file, and call ShapeLibrary.LoadFrom when the application loads.
Mas-Tool
Reply #2 - Mar 23rd, 2010 at 9:11pm
Just perfect !
Many thanks !  Grin
