Normal Topic Disable resizing (Read 1696 times)
Denis_Vuyka
Disable resizing
Mar 26th, 2010 at 3:09pm
I need to allow only selection of the node without resizing. I've tried "DoNothing" behavior but it does not allow selecting the node clicked.
Any ideas how to accomplish my task?
Re: Disable resizing
Reply #1 - Mar 26th, 2010 at 3:45pm
Try setting the nodes' EnabledHandles property to None.
Denis_Vuyka
Reply #2 - Mar 26th, 2010 at 3:56pm
Thanks that works. However I see all handles painted red. Is there an option just to display selection border without handles?
Reply #3 - Mar 26th, 2010 at 4:17pm
You could also change the HandlesStyle property, e.g. set node.HandlesStyle = HandlesStyle.DashFrame; Alternatively, instead of using these properties you might handle the NodeModifying event and call e.CancelDrag().
