Normal Topic Multi lingual support in Flowchart (Read 1884 times)
aseemshirgaokar
Apr 12th, 2010 at 2:46pm
Japanese text cannot be seen properly
I can type japanese in the editor when i double click a node. But after editing is complete the node text turns to garbage.
I am currently using the trial version. Is this a problem with the trial version or is it a limitation?
I have japanese clients and multi-lingual support is a must!
Re: Multi lingual support in Flowchart
Reply #1 - Apr 12th, 2010 at 3:04pm
Try setting the Font property to a Unicode font, e.g. Arial Unicode MS.
aseemshirgaokar
Reply #2 - Apr 12th, 2010 at 3:35pm
Yup.. that did it..thanks!
Reply #3 - Apr 12th, 2010 at 3:41pm
By the way you could also disable the StringFormatFlags.NoFontFallback flag in TextFormat.FormatFlags, and then "Arial" should automatically fall back to "Arial Unicode MS".
