Normal Topic How to add text inside the link? (Read 1110 times)
venki5star
Oct 23rd, 2010 at 1:10pm
My requirement is to add TEXT inside the decision link as like below.
Also there should be down arrow added along with the text, when user click on that arrow it should show context menu.
---- Failure ---- /\ ---- Success ----
Please help any one me. Its is really very urgent
Castle Rider
Re: How to add text inside the link?
Reply #1 - Oct 25th, 2010 at 3:47am
You can either use custom drawing or attached nodes to implement this.
Custom drawing can be done by deriving from the DiagramLink class and overriding its Draw method, or by setting the CustomDraw property and handling the DrawLink event. Then you can use the DrawingContext methods to render the arrow and labels.
The other option is to use the AttachTo method to attach three auxiliary nodes to the link so that they display the labels and menu arrow. You can also combine this with a LinkModifying handler that distributes the attached nodes uniformly along the horizontal link segment.
