Normal Topic Shape templates with fixed points (Read 1687 times)
jf2020
I love FlowChart!
Feb 15th, 2011 at 6:59am
We are providing our users the possibility to add various shapes to their diagram like arrows. However the most common complaint is that they just look ugly. The reason is that when you resize the arrow everything gets scaled including the head of the arrow. What they want is the same behaviour as for autoshapes in PowerPoint or Visio, i.e. the head of the arrow keeps a fixed size when resizing the arrow (unless the size of the bounding box is too small at which point you also start resizing the head).  As templates use percentages to define points, I have implemented a small function that dynamically creates a new shape with the correct percentages each time the node is resized and sets it as teh current shape template of that node.  This works, however it seems a bit ugly and it would be nice to have that as a core feature of FlowChart. I'm a bit surprised that it does not exist yet so maybe I completely missed something?
Re: Shape templates with fixed points
Reply #1 - Feb 15th, 2011 at 7:54am
In Visio such shapes are defined via parameterized formulas that calculate point coordinates depending on the shape's width an height. We have a small script interpreter in the mindfusion.reporting tool that should be capable of parsing such formulas; we will try to integrate it into the flowchart control to allow creating dynamic shapes.
jf2020
I love FlowChart!
Reply #2 - Feb 15th, 2011 at 8:36am
Stoyan,
That would be wonderful.  Let me know when you have a beta version ready for testing  Wink
Jean-Francois
Reply #3 - Mar 29th, 2011 at 12:54pm
Here is the beta:
https://mindfusion.eu/_beta/fcnet562_formula_shapes.zip
It lets you pass Visio-like shape formulas to the Shape constructor:
string outline = @"
	my = Height / 2;
	ah = Min(10, Height / 4);
	aw = Min(20, Width / 2);
	MoveTo(0, my - ah);
	LineTo(Width - aw, my - ah);
	LineTo(Width - aw, 0);
	LineTo(Width, my);
	LineTo(Width - aw, Height);
	LineTo(Width - aw, my + ah);
	LineTo(0, my + ah);
Shape shape = new Shape(outline, "test");
diagram.DefaultShape = shape;
The sample above create an arrow shape with fixed shaft width and arrowhead length, which will still shrink when the node gets small due to the Min calls.
