Normal Topic Unfold/Fold ContainerNode (Read 1346 times)
Novice
Apr 28th, 2011 at 11:39am
Hi
When the user clicks on a ContainerNode to fold/unfold I run a method to shift other ContainerNodes so that they are not eg overlapped by an unfolded ContainerNode.
These operations are caught as different actions by the undomanager (as is expected) but I would like to enable the user to undo them as a single composite action.
Please can you suggest an approach I might take to achieve this.
Re: Unfold/Fold ContainerNode
Reply #1 - Apr 28th, 2011 at 12:10pm
Try merging the undo records, using intermediate composite command to avoid counting the node modification ones:
private void diagram_ContainerFolded(object sender, NodeEventArgs e)
	CompositeCmd cmd = diagram.UndoManager.StartComposite("");
	// shift nodes
	cmd.Execute();
	diagram.UndoManager.History.MergeUndoRecords(2, "Fold container");
