Normal Topic Rearrange Containers on Fold/Unfold? (Read 1736 times)
ThomasK
May 13th, 2011 at 12:22pm
i have several ContainerNodes, each is a new graph.
The layout places them vertically:
layout.MultipleGraphsPlacement = MultipleGraphsPlacement.Vertical;
When i fold one container i want the diagram to be rearranged so the gap between the now folded container and the next ohne is closed.
And when i unfold the container it has to be rearranged so the distance to the next one is the same again.
layout.Arrange(myDiagram) seems to ignore the fact that a container is folded.
How can i get this done?
thx
Re: Rearrange Containers on Fold/Unfold?
Reply #1 - May 14th, 2011 at 6:48am
Indeed the GraphsPlacement function allocates space for container's children even if the container is folded. There is no way to prevent that now. If you only need to arrange all containers vertically, you could directly set their Bounds instead of using Layout.Arrange:
private void diagram_ContainerFolded(object sender, NodeEventArgs e)
	float x = 10, y = 10, p = 5;
	foreach (DiagramNode node in diagram.Nodes)
		if (node is ContainerNode)
			node.Move(x, y);
			y += node.Bounds.Height + p;
ThomasK
Reply #2 - May 16th, 2011 at 11:49am
Hi Stoyan,
thank you i think this should work in this case.
