Normal Topic how I add a shape node manually (Read 4521 times)
Hamdy Ghanem
May 25th, 2011 at 10:45am
I want to add a node manually to the diagram
in a web project
Re: how I add a shape node manually
Reply #1 - May 25th, 2011 at 10:51am
Do you mean you need to draw nodes with the mouse in ImageMap mode?
Hamdy Ghanem
Reply #2 - May 25th, 2011 at 10:52am
sorry
I mean programatically
Reply #3 - May 25th, 2011 at 10:57am
You can use the diagram.Factory methods for built-in node types, or add nodes to diagram.Nodes for custom types:
var node = new MyNode();
diagram.Nodes.Add(node);
Hamdy Ghanem
Reply #4 - May 25th, 2011 at 11:09am
it works
thanx
Hamdy Ghanem
Reply #5 - May 25th, 2011 at 12:43pm
I used the tad to save a class
node.tag = new class
when I am saving
n.tag= nothing
Hamdy Ghanem
Reply #6 - May 25th, 2011 at 1:21pm
In this topic
http://mindfusion.eu/Forum/YaBB.pl?board=netdg_disc;action=display;num=1254243822;start=
u replied by using this event
void diagram_SerializeTag(object sender, SerializeTagEventArgs e)
but I could not find this event
I am working in a web application Asp.net , vb.net
Reply #7 - May 25th, 2011 at 4:50pm
It's an event of the Diagram class. In VB.NET you will have to use the AddHandler command to attach a handler dynamically at each page request.
Hamdy Ghanem
Reply #8 - May 26th, 2011 at 8:40am
I did the handler but not firing
What about the class (object) that I will put it in the tag
<Serializable()> _
Public Class test
do I have to inherited from any another class?
Reply #9 - May 26th, 2011 at 12:25pm
Are you saving binary or XML files? The Serializable attribute should work for binary ones, the SerializeTag event for XML. You might need SerializeTag in any case though, since the control's view state is stored as compressed XML.
