Normal Topic RouteDescriptor Constructor (Read 2228 times)
Julien_Dechene
Jun 20th, 2011 at 7:14pm
Hi, sifting through the source code of Mindfusion.Diagramming I found out something strange that I am not sure if it is to be that way. In the RouteDescriptor class constructor (contained in DiagramLink.cs) the last two lines read :
this.originConnection = originConnection;
this.destConnection = originConnection;
Is this right ?? Intuitively I would expect it to be :
[b]this.destConnection = destConnection ;[/b]
Is there a reason why it is like that ? Enlighten me please.
Julien Dechêne
Re: RouteDescriptor Constructor
Reply #1 - Jun 20th, 2011 at 7:39pm
Yes, I think it should be set to destConnection. It seems to affect the feature where orthogonal bends in polyline links are chopped by GridRouter, and causes the bend at destination to not be removed. Anyway if you need to access the destination node through this descriptor from custom code, feel free to fix that in your copy.
Julien_Dechene
Reply #2 - Jun 20th, 2011 at 8:42pm
Ok thanks for the response, I am using cascading linkstyle so from what you are saying (or from what I think you are saying) it won't affect the behavior of my links. Did I get this right ?
Thanks !
Reply #3 - Jun 21st, 2011 at 7:33am
Right, from what I can see the incorrect value is used for polyline links when SmartPolylineEnds and GridRouter are enabled. It doesn't affect the routing much even then, but of course we'll fix that for the next release.
