Normal Topic Need to override AnchorPoint linking behavior (Read 1697 times)
snype
Aug 24th, 2011 at 4:15pm
I have a DiagramNode with two anchorpoints one is valid for creating link and another one is not. When I try to create a link from the invalid anchorpoint, it automatically diverts the link to the valid anchorpoint and start the link from there. How can I override this behavior.
My requirement says if the user tries to start a link from an invalid anchor point , then donot allow him to create a link from that node at all. It's the user's job to start the link from valid anchor point.
Re: Need to override AnchorPoint linking behavior
Reply #1 - Aug 24th, 2011 at 5:04pm
You can do that using a custom behavior class that returns null if there's no valid anchor point under the mouse position. The code here should be a good starting point, just add a check for what you consider a valid anchor point and return null if the point is invalid:
http://mindfusion.eu/Forum/YaBB.pl?board=diaglite_disc;action=display;num=128273...
