hello Stoyo
i made recently a quite complex diagram with TableNodes and icons in cells and mouseover tooltips etc, but sometimes (i cannot reproduce this issue) - it looks like if i stay for awhile over a node hoovering so that the tooltip just starts to get drawn, i get a little tooltip "remnant" or artefact like a 5x3 pixels big empty tooltip, and then driving over another or this node the whole app crashes with:
System.InvalidOperationException was unhandled
Message=Specified element is already the logical child of another element. Disconnect it first.
Source=PresentationFramework
StackTrace:
at System.Windows.FrameworkElement.ChangeLogicalParent(DependencyObject newParent)
at System.Windows.FrameworkElement.AddLogicalChild(Object child)
at System.Windows.Controls.ContentControl.OnContentChanged(Object oldContent, Object newContent)
at System.Windows.Controls.ContentControl.OnContentChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEvent
Args e)
at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEvent
Args e)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEv
entArgs args)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp)
at System.Windows.Data.BindingExpressionBase.Invalidate(Boolean isASubPropertyChange)
at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange)
at System.Windows.Data.BindingExpression.ScheduleTransfer(Boolean isASubPropertyChange)
at MS.Internal.Data.ClrBindingWorker.NewValueAvailable(Boolean dependencySourcesChanged, Boolean initialValue, Boolean isASubPropertyChange)
at MS.Internal.Data.PropertyPathWorker.UpdateSourceValueState(Int32 k, ICollectionView collectionView, Object newValue, Boolean isASubPropertyChange)
at MS.Internal.Data.PropertyPathWorker.OnDependencyPropertyChanged(DependencyObject
d, DependencyProperty dp, Boolean isASubPropertyChange)
at MS.Internal.Data.ClrBindingWorker.OnSourceInvalidation(DependencyObject d, DependencyProperty dp, Boolean isASubPropertyChange)
at System.Windows.Data.BindingExpression.HandlePropertyInvalidation(DependencyObjec
t d, DependencyPropertyChangedEventArgs args)
at System.Windows.Data.BindingExpressionBase.OnPropertyInvalidation(DependencyObjec
at System.Windows.Data.BindingExpression.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args)
at System.Windows.DependentList.InvalidateDependents(DependencyObject source, DependencyPropertyChangedEventArgs sourceArgs)
entArgs args)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
at System.Windows.Controls.ToolTipService.SetToolTip(DependencyObject element, Object value)
at System.Windows.FrameworkElement.set_ToolTip(Object value)
at MindFusion.Diagramming.Wpf.Diagram.YM(Object
