Normal Topic Limiting size of image drawn with CreateBmpFromChart() (Read 2874 times)
steve
Mar 7th, 2012 at 4:30pm
Hi, I'm doing some support work on an old application that is rendering an organisational structure using FlowChartX.NET version 3.2.1.20797.
In some cases the generated image is pretty huge (over 60 000px wide) when I call CreateBmpFromChart(), which then causes a GDI+ error when I try to save the bitmap to a stream or Image.
I've attached the class that creates the flowchart and renders the image if you would like to check my code - the error occurs on line 418:
> bmp.Save(ms, codec, eps);
Is there a way to prevent this from happening either by setting maximum width/height values for the generated image, or by rendering the image to a number smaller pieces?
Steve
OrganisationalStructure.txt (Attachment deleted)
Re: Limiting size of image drawn with CreateBmpFromChart()
Reply #1 - Mar 8th, 2012 at 7:15am
Current versions of the control have a CreateImage(RectangleF)  overload that lets you specify what region of the flowchart should be copied to the image. You could use it to export several smaller images. If there is no such CreateBmpFromChart overload in the version you are using, you could temporarily set DocExtents to a smaller rectangle before calling CreateBmpFromChart to achieve the same effect.
steve
Reply #2 - Mar 8th, 2012 at 11:27am
Hi Stoyo,
Exporting to smaller images works fine.
Thanks for the help!
Steve
