Normal Topic Winforms version issues (Read 4511 times)
billcollis
I love mindfusion
Apr 2nd, 2012 at 9:08am
I have installed Winforms Pack 2012R1 onto my new PC with VS2010
I opened an existing project and seem to have version issues between the existing version of Mindfusdion.Diagramming.Winfiorms (5.6.4.22118)  and the new version (5.7.0.22694)
I also tried creating a new project however the same issue occurs when trying to add a DiagramView to that.  'Failed to create component 'DiagramView" the system could not load the old version.
I have tried removing the references and adding them again, no luck.
Specific Version is set to false.
Any ideas what to try next?
thanks
Re: Winforms version issues
Reply #1 - Apr 2nd, 2012 at 9:23am
If there is a PublicKeyToken value set for DiagramView in the project's licenses.licx file, try replacing it with "null" and rebuilding.
billcollis
I love mindfusion
Reply #2 - Apr 2nd, 2012 at 10:13am
In the existing project there was a licenses.licx file with a key value,
First I set that to null but it made no difference.
I am still getting the failed to create component diagramview and the error still contains the PublicKeyTokien=a0d18338041985ba
I also tried changing the version in this file too but it made no difference.
In the new project there wasn't a licenses.licx file.
Any more ideas?
thanks
Bill
Reply #3 - Apr 2nd, 2012 at 11:57am
Is that error shown by the compiler, the VS form designer, or by the application at run-time?
billcollis
I love mindfusion
Reply #4 - Apr 2nd, 2012 at 5:18pm
by the form designer when I try to add a digramview
Reply #5 - Apr 2nd, 2012 at 6:08pm
Is it a clean install or have you installed over a previous version?
billcollis
I love mindfusion
Reply #6 - Apr 3rd, 2012 at 9:42am
It was a clean install of both VS2010 and Winforms 2012R1
The first thing I did after the installs was try to open an existing project.
I removed the references in the project to the old versions and added references to the new versions which I found in the online help. Then I tried to open a form within the project and I get the error in the first  screen shot attached.
If I ignore and continue  then I find the diagramview has disappeared from the form and get the second screen shot when I try to add a new diagram view
When I create a new project and try and add a diagramview to it I also get the error in the second screen shot.
Reply #7 - Apr 3rd, 2012 at 10:47am
It's a bug in the installer. Remove the following registry key and you should be able to open the form:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\.NETFramework\v4.0.30319\Assem
blyFoldersEx\MindFusion.Pack Design
We'll upload updated installer on the clientsarea.eu site in a few days.
billcollis
I love mindfusion
Reply #8 - Apr 3rd, 2012 at 6:27pm
I do not have that key
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft has a key with no value
I do have a key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework\v4.0.30319\AssemblyFoldersEx
and deleted that one and it now works
thanks Grin
