Normal Topic Semi-transparent and grayed SVG nodes (Read 3546 times)
Vladimir
Apr 2nd, 2012 at 11:20pm
Hello!
We have such diagramming tasks that require node semi-transparency and graying a node (e.g. show node as disabled).
How could I do that?
1. I have no idea how to rich transparency.
2. I think that I could gray a node with CustomDraw – just overlay a gray rectangle over the node in additional mode. Am I right or there are more elegant way to do that?
Thank you in advance!
Best wishes,
Vladimir.
Re: Semi-transparent and grayed SVG nodes
Reply #1 - Apr 3rd, 2012 at 9:19am
At this time there is no SvgNode property available to make the node semi-transparent. You will have to set fill-opacity attribute on your SVG shapes, and load them as separate SvgContent objects to use for transparent nodes.
Vladimir
Reply #2 - Apr 3rd, 2012 at 12:35pm
OK. I see.
Thank you for your post.
What about grayed node (not transparent)?
Please look at the right node on the picture labeled "Grayed". It's not transparent.
How to do that?
Reply #3 - Apr 3rd, 2012 at 2:05pm
You could try handling the DrawNode event and filling the polygon returned by SvgContent.GetConcaveHull() with translucent gray.
Reply #4 - Apr 3rd, 2012 at 6:06pm
One addition - GetConcaveHull returns the points in SVG coordinates, which you will need to map to the node's bounding rectangle as shown below.
node.CustomDraw = CustomDraw.Additional;
private System.Drawing.SolidBrush grayBrush =
	new System.Drawing.SolidBrush(Color.FromArgb(100, Color.Gray));
private void diagram_DrawNode(object sender, DrawNodeEventArgs e)
	SvgNode svgNode = e.Node as SvgNode;
	if (svgNode != null && !e.Shadow)
		PointF[] points = svgNode.Content.GetConcaveHull();
		GraphicsState gs = e.Graphics.Save();
		MapCoordinateSystem(e.Graphics,
			svgNode.Content.GetBounds(), e.Node.Bounds);
		e.Graphics.FillPolygon(grayBrush, points);
		e.Graphics.Restore(gs);
private void MapCoordinateSystem(IGraphics graphics,
	RectangleF newBounds, RectangleF oldBounds)
	graphics.TranslateTransform(oldBounds.X, oldBounds.Y);
	graphics.ScaleTransform(
		oldBounds.Width / newBounds.Width,
		oldBounds.Height / newBounds.Height);
	graphics.TranslateTransform(-newBounds.X, -newBounds.Y);
The code above assumes you are using ContentAlign=Stretch. Since GetConcaveHull() isn't very fast, you might want to cache the points for each SvgContent in some Dictionary.
Vladimir
Reply #5 - Apr 3rd, 2012 at 10:15pm
Yes, it's not fast but exactly what I need.
Thank you!
