Normal Topic LaneGrid rowcount (Read 4355 times)
binuvc
LaneGrid rowcount
Apr 27th, 2012 at 10:17am
I added few blank lanes to a diagram but the LaneGrid.RowHeaders.Count is returning only the number of lanes with atleast one node in it.
Even diagramLite.GetRect() is not considering lanes with out any nodes in it.
Please advice
BinuVC
Re: LaneGrid rowcount
Reply #1 - Apr 27th, 2012 at 12:57pm
How exactly do you add the blank lanes? Keep in mind that LaneGrid.RowHeaders.Count returns the number of the top-level rows only. If you add rows as children to other rows, this property will not reflect the change. However, you can get the number of leaf rows in the grid through LaneGrid.RowCount.
binuvc
Reply #2 - Apr 27th, 2012 at 1:04pm
Hi
I am adding the row header as follows
diagramLite.LaneGrid.RowHeaders.Add(header);
and this is how I am trying to loop through all the rows
for (int i = 0; i < diagramLite.LaneGrid.RowCount; i++)
But after adding few rows, some with nodes and some without, the count returns only the number of rows with nodes.
BinuVC
Reply #3 - Apr 27th, 2012 at 2:07pm
I am not able to reproduce this. The rows and columns in the lane grid have no notion of diagram nodes and the returned count should not be affected by this in any way. Is it possible that a swimlane layout has clipped some of the rows as discussed in this thread?
binuvc
Reply #4 - Apr 27th, 2012 at 3:27pm
Please find the attaced sample code. Also included in the solution is a txt file listing the issues.
My requirement was to resize the host diagramlite control to to the effective size of the lanegrid after applying the layout. Since empty lanes are dissappearing, GetRect is not considering the height of those lanes.
Please advice.
BinuVC
SilverlightApplication2_001.zip (Attachment deleted)
Reply #5 - Apr 28th, 2012 at 12:50pm
Utilities.GetRect is a convenience method, which returns a rectangle with the current size of the specified element, it doesn't auto-calculate size based on the element's contents. What I would have recommended is actually something that already exists in your sample:
var rect = diagramLite.LaneGrid.GetColumnHeaderBounds();
rect.Union(diagramLite.LaneGrid.GetRowHeaderBounds());
diagramLite.Bounds = rect;
Isn't this code doing exactly what you need?
