Normal Topic why shapeLibraryLocation can't be used (Read 2021 times)
webdev
Nov 8th, 2012 at 9:37am
i used widget--diagram to draw a flow chart and designed own
shapelist for it.  i tested it on localhost and it succeed.
but when visiting from the server(IIS).   i can't see my own shapes and the shapes in the shapelist are the default shapes.
i have settled the object-diagram.shapelibrarylocation .....
who can help me.thanks... Cry
Re: why shapeLibraryLocation can't be used
Reply #1 - Nov 8th, 2012 at 10:33am
Either rename the shape library file extension to xml (and update the location property), or add .shl to the IIS static files extensions list. Otherwise IIS won't serve the file but return 404 code.
webdev
Reply #2 - Nov 9th, 2012 at 5:36am
problem has been solved
thx  Cheesy
