Normal Topic how can we apply Color and thickness property to First Element Template in shape constructor (Read 2806 times)
Chetna Tumme
Dec 11th, 2012 at 8:39am
var shape = new Shape(
                        new ElementTemplate[]
                        new LineTemplate(20, 20, 0, 30,Colors.Black,3),
                        new LineTemplate(0, 30, 20, 40,Colors.Black,3),
                        new LineTemplate(20, 40, 0, 30),
                        new LineTemplate(0, 30, 20, 20)
                        new LineTemplate(70, 20, 90, 30,Colors.Black,3),
                        new LineTemplate(90, 30, 70, 40,Colors.Black,3),
                        new LineTemplate(70, 40, 90, 30),
                        new LineTemplate(90, 30,70, 20),
                    FillRule.Nonzero, "CommunicationPath",
                    new[]
                        new ShapeDecoration(
                            new LineTemplate(0, 30, 90, 30),
                            new LineTemplate(90, 30, 0, 30)
                          },Brushes.Black,FillRule.Nonzero,new Pen(Brushes.Black,1.0,DashStyles.Dash)
            var shapeNode = new ShapeNode
                                    Shape = shape,
                                    Bounds = new Rect(60, 60, 50, 50),
                                    Constraints = {KeepInsideParent = true},
                                    Name = "Node",
                                    Text = "Node",
                                    Brush = new SolidColorBrush{Color = Colors.Magenta}
            mindFusionDiagram.Nodes.Add(shapeNode);
1. the width is getting applied properly to Line Templates in Second Element Template...
2. But In First Element Template[] width is not getting applied
Please provide solution
Re: how can we apply Color and thickness property to First Element Template in shape constructor
Reply #1 - Dec 11th, 2012 at 11:05am
The first array defines elements of the shape outline and they are rendered using the node's Stroke and StrokeThickness. You could copy the element you need to the second array, repeating it as a decoration line; that should render it using the color and thickness specified as LineTemplate arguments.
