Normal Topic Projection color on ruler doesn't show properly. (Read 9537 times)
Yogendra
Jan 29th, 2013 at 9:59am
I am working with diagramming.mindfussion diagram. I am using ruler in which i placed diagram.
code is here in xaml:-
<diag:Ruler Name="ruler"
                        HorizontalAlignment="Stretch"
                        VerticalAlignment="Stretch"
                        Unit="Pixel"
                        ProjectionColor="#5E6A6AD4">
<diag:Diagram Name="diagram"
                              HorizontalAlignment="Left"
                              GridSizeX="10"
                              GridSizeY="10"/>
and code behind
With diagram
            .AutoResize = AutoResize.None
            .Behavior = Behavior.Modify
            .AlignToGrid = False
            .AutoScroll = True
            .MeasureUnit = MindFusion.Diagramming.Silverlight.GraphicsUnit.Pixel
            .AdjustmentHandlesSize = 10
            .ShapeBrush = NodeBrush
            .Bounds = BGBounds
            .ShowGrid = True
        End With
When i placed any shape node in diagram say the top is at the position 400 as per the ruler of the diagram. But the projection color shows a little variation. It shows 395 as for the above case. How can I sync both the ruler's value and the projection color for the shape node?
If I do diagram.AlignToGrid=True then problem still persist.
Thanks in advance.  Sad
Re: Projection color on ruler doesn't show properly.
Reply #1 - Jan 29th, 2013 at 2:33pm
I can't see this happening. Are you sure the projection stripe touches that 395 tick? Here is what the projection for a node at 400x400 looks like in our test app after zooming in to show the '5 labels.
Yogendra
Reply #2 - Jan 29th, 2013 at 2:58pm
You can see in this snap shot.
Reply #3 - Jan 30th, 2013 at 4:44pm
Have you set any Silverlight layout properties such as Margin on the diagram? The Ruler expects that the diagram will fill it completely and could be showing the projection and ticks with some offset if there are margins.
Yogendra
Reply #4 - Feb 22nd, 2013 at 4:45am
Thanks stoyo.
