Normal Topic Assigning calculated control points to link, may result in to link crossing shape with obstacle true (Read 3296 times)
Chetna Tumme
Feb 15th, 2013 at 6:10am
Hi Stoyan,
I am assigning control points to link which are calculated by me in code.
So sometimes such link with calculated control points(not provided by mind fusion) croses a shape with obstacle property set to true.
But I want like follows:
Even if I am assigning calculated control points, the link should not cross the shape with obstacle property set to true.
That mean the libk with calculated control points should dynamically calculate its path if any shape is in its path.
Else if no shape is in its path then take the calculated control poits.
Is this possible?
Re: Assigning calculated control points to link, may result in to link crossing shape with obstacle true
Reply #1 - Feb 15th, 2013 at 10:02am
After assigning points, loop over diagram.Nodes and check if link.Intersects(node) returns true. Call link.Route() if it does.
