Normal Topic Arrange Links (Read 1193 times)
KillaChris
Arrange Links
Mar 14th, 2013 at 2:13pm
Hello
i added a Screenshot as attachment. As you can see on the Screenshot I'm using a SwimLaneLayout.
There is one important Node. That node in the middle with the red Corner.
All links that point to other nodes are starting from this node.
And all links that are starting from other nodes end in this node.
Now as you can see the links are somehow confusing.
It would be nice if the links could look like on Screenshot2 (I changed that with a graphic programm).
Is there somehow a possibility to manage this?
Re: Arrange Links
Reply #1 - Mar 14th, 2013 at 2:40pm
Set the following points for each link, where top is the vertical position of long segments:
var off = 5;
var or = link.Origin.Bounds;
var dr = link.Destination.Bounds;
var top = 10;
SetLinkPoints(link,
	new PointF(or.Left, or.Y + or.Height / 2),
	new PointF(or.Left - off, or.Y + or.Height / 2),
	new PointF(or.Left - off, top),
	new PointF(dr.Right + off, top),
	new PointF(dr.Right + off, dr.Y + dr.Height / 2),
	new PointF(dr.Right, dr.Y + dr.Height / 2));
void SetLinkPoints(DiagramLink link, params PointF[] points)
	link.AutoRoute = false;
	link.Shape = LinkShape.Cascading;
	link.ControlPoints.Clear();
	link.ControlPoints.AddRange(points);
	link.UpdateFromPoints(false, true);
