Normal Topic How to serialize the DiagramDocument Tag property (Read 2008 times)
Sabrina C.
Apr 23rd, 2013 at 3:12pm
We're trying to serialize a class set in the Tag property of the DiagramDocument class (hold by the TabbedDiagramView Document property).
We need to serialize data which is independent from the presence of pages in the Document, since we require to serialize also empty documents with our custom data in Tag property. Unfortunately it seems that the Tag property is never serialized in the output XML.
Can you help?
Thanks, Agus
Re: How to serialize the DiagramDocument Tag property
Reply #1 - Apr 24th, 2013 at 6:15am
You could call diagramDoc.SaveToXml(XmlDocument), add your custom data using the XmlDocument API methods, and then save to file via XmlDocument.Save().
Reply #2 - Apr 25th, 2013 at 7:57am
This version will now save Tag automatically or raise Serialize/DeserializeTag events to let you save it:
http://mindfusion.eu/Forum/YaBB.pl?num=1366875705
