Normal Topic ButtonComponent (Read 1357 times)
billcollis
I love mindfusion
ButtonComponent
Jun 8th, 2013 at 7:42pm
I have buttoncomponents working with clicked event
but want to use mousedown and mouseup events separately how do I do this and identify the button that was clicked
thanks
Re: ButtonComponent
Reply #1 - Jun 9th, 2013 at 7:39am
You need to inherit the ButtonComponent class and override the OnMouseDown and OnMouseUp methods, then raise some custom events. The following code illustrates a sample implementation of the custom button:
public class MyButton : ButtonComponent
	public override void OnMouseDown(PointF point)
		base.OnMouseDown(point);
		if (Down != null)
			Down(this, EventArgs.Empty);
	public override void OnMouseUp(PointF point)
		base.OnMouseUp(point);
		if (Up != null)
			Up(this, EventArgs.Empty);
	public event EventHandler Down;
	public event EventHandler Up;
If you are loading the contents of your composite node through a XmlLoader, the class of the custom button should be resolved automatically. If this is not the case you could supply a custom ITypeResolver object to the XmlLoader.Load method.
billcollis
I love mindfusion
Re: ButtonComponent
Reply #2 - Jun 13th, 2013 at 10:38am
I see where I had messed up now
All working well
