Normal Topic How to change font for node's tooltip (Read 2549 times)
Ada
Mar 28th, 2014 at 12:12am
I want to show some tool-tip with lined up format, so I need to set the font to some fixed width font, for example: Courier New.
I changed font for node, diagram, diagramview, form, but the tool tip's font is still the old one, how can change it?
Thanks.
Ada
Re: How to change font for node's tooltip
Reply #1 - Mar 28th, 2014 at 6:54am
The only way I could find to implement that in Windows Forms is via custom drawing:
diagramView.ShowToolTips = true;
diagramView.ToolTipControl.OwnerDraw = true;
diagramView.ToolTipControl.Draw += (s, args) =>
	var font = new Font("Courier New", 20);
	args.Graphics.FillRectangle(
		Brushes.White, args.Bounds);
	args.Graphics.DrawString(
		args.ToolTipText, font, Brushes.Black, 0, 0);
	font.Dispose();
diagramView.ToolTipControl.Popup += (s, args) =>
	args.ToolTipSize = TextRenderer.MeasureText(
		diagramView.ToolTipControl.GetToolTip(diagramView), font);
	font.Dispose();
You will have to take care of drawing the tooltip shape too: balloon, rectangle, or whatever you need.
Ada
Reply #2 - Apr 7th, 2014 at 9:17pm
Thanks Stoyan ,
It works, now the tooltip looks much better.
