Page Index Toggle Pages: 1 ... 12 13 [14] 15 16 ... 21 Send TopicPrint
Locked Topic Link between two nodes (Read 157270 times)
shrinivas
Re: Link between two nodes
Reply #195 - Jul 21st, 2014 at 12:51pm
Actually i am exporting my flowchart to PDF and its working fine, but i want to show dialogbox to user to add file name and to select location.
Can you tell me how i can implement this in my code ?.
Reply #196 - Jul 21st, 2014 at 1:28pm
Try the solution from following post, only change the media type to "application/pdf" and append the PDF file data instead of CSV records:
http://sandeep-tada.blogspot.com/2012/10/c-export-to-excel-file-and-save-with.ht...
shrinivas
Reply #197 - Jul 22nd, 2014 at 4:09am
Stoyo wrote on Jul 21st, 2014 at 1:28pm:
Not in this way i want proper savedialogbox which is from visual studio.
Reply #198 - Jul 22nd, 2014 at 7:09am
I think there's save file dialog component only for desktop applications. From ASP.NET you will have to set the content type and return http file response, which should make the browser show its own save dialog. You can find an example that sends PDF files from server here, forcing a save dialog instead of letting the browser open the PDF directly:
http://aspalliance.com/259
shrinivas
Reply #199 - Jul 23rd, 2014 at 10:31am
I want to generate multiple VISIO files at once without loading XML file in diagram control, How I can implement ?
and I want to implement this windows not in asp.net its C# windows forms.
shrinivas
Reply #200 - Jul 23rd, 2014 at 10:31am
Stoyo wrote on Jul 22nd, 2014 at 7:09am:
Okay, Thanks.
Reply #201 - Jul 23rd, 2014 at 10:45am
shrinivas wrote on Jul 23rd, 2014 at 10:31am:
Hello, I want to generate multiple VISIO files at once without loading XML file in diagram control, How I can implement ? and I want to implement this windows not in asp.net its C# windows forms.
You could use our Windows Forms component, build a diagram model (using same API as ASP.NET's Diagram class) and export it with VisioExporter. If you don't want to use the Diagram control at all, you will have to build the Visio XML yourself by its file format specification (http://msdn.microsoft.com/en-us/library/ms426602(v=office.12).aspx) or use another library.
shrinivas
Reply #202 - Jul 23rd, 2014 at 11:40am
Is it possible to embed MindFusion XML to VISIO XML in C#, if yes then how?
I mean is there any utility or something else to do?
Reply #203 - Jul 23rd, 2014 at 2:02pm
Using the XmlDocument API you could move the XML content saved by the diagram to a child element of the Visio document after exporting:
VisioExporter vex = new VisioExporter();
vex.ExportInvisibleItems = false;
vex.ExportTablesAsGroups = true;
vex.DynamicsOff = true;
vex.Export(diagram, sfd.FileName);
var visioDoc = new XmlDocument();
visioDoc.Load(sfd.FileName);
var diagDoc = new XmlDocument();
diagram.SaveToXml(diagDoc);
var diagElement = visioDoc.ImportNode(
	diagDoc.DocumentElement, true);
visioDoc.DocumentElement.AppendChild(diagElement);
visioDoc.Save(sfd.FileName);
and later load like this
visioDoc.Load(fileName);
var diagElement = visioDoc.GetElementsByTagName("Diagram")[0];
diagElement = diagDoc.ImportNode(diagElement, true);
diagDoc.AppendChild(diagElement);
diagram.LoadFromXml(diagDoc);
shrinivas
Reply #204 - Jul 24th, 2014 at 4:37am
Here you are using,
diagram is object of canvas control right and what is mean by sfd.FileName ?
and code is of web or windows?
please mention all in details .
Reply #205 - Jul 24th, 2014 at 4:49am
sfd.FileName is the file path for exported Visio file selected via Windows Forms SaveFileDialog. diagram is a Diagram instance.
shrinivas
Reply #206 - Jul 24th, 2014 at 5:25am
Stoyo wrote on Jul 24th, 2014 at 4:49am:
It means sfd.FileName is XML file path right
Reply #207 - Jul 24th, 2014 at 5:44am
It's the path for the exported Visio VDX file. Then the diagram's XML is appended to it via intermediate XmlDocument, without actually saving the diagram to a separate file.
shrinivas
Reply #208 - Jul 24th, 2014 at 6:35am
Can u send me link to download windows MindFusion diagramming exe or all dll those required for that.
Reply #209 - Jul 24th, 2014 at 7:21am
You can use the diagramming.dll and export.visio.dll from ASP.NET version in your WinForms application if all you need is exporting to Visio, just add references to them to your project. The WinForms and ASP.NET versions include the same model and import/export assemblies, they only differ in the view-specific assemblies that build upon the respective UI platform, e.g. diagramming.winforms.dll and diagramming.webforms.dll.
