Page Index Toggle Pages: 1 ... 13 14 [15] 16 17 ... 21 Send TopicPrint
Locked Topic Link between two nodes (Read 157369 times)
shrinivas
Re: Link between two nodes
Reply #210 - Jul 24th, 2014 at 10:15am
Can you tell me exact version of VISIO which supports diagrams generated from MindFusion.
Reply #211 - Jul 24th, 2014 at 11:25am
VisioExporter creates files in Visio 2003 VDX format. Newer versions should be able to open them too.
shrinivas
Reply #212 - Jul 25th, 2014 at 3:43am
Can u tell me how to zoom in and out diagrams on web page ?
shrinivas
Reply #213 - Jul 25th, 2014 at 4:15am
Like magnifier by simply using scroll button of mouse.
Reply #214 - Jul 25th, 2014 at 5:17am
You could change the ZoomFactor property from mousewheel event handler:
function onLoad()
	$get("diagramView").addEventListener("mousewheel", onMouseWheel, false);
	$get("diagramView").addEventListener("DOMMouseScroll", onMouseWheel, false); // firefox
function onMouseWheel(e)
	var diagram = $find("diagramView");
	var oldZoom = diagram.getZoomFactor();
	var newZoom = Math.max(10,
		oldZoom + (e.wheelDelta / 60 || -e.detail / 2));
	diagram.setZoomFactor(newZoom);
	return false;
shrinivas
Reply #215 - Jul 25th, 2014 at 8:30am
When I am exporting to VISIO format its not displaying color :"#00CCFF" Its showing white but in web page its proper even in PDF also correct.
Can u tell me any solution on that?
Reply #216 - Jul 25th, 2014 at 10:51am
To what property are you assigning that color?
shrinivas
Reply #217 - Jul 25th, 2014 at 12:15pm
Stoyo wrote on Jul 25th, 2014 at 5:17am:
function onLoad()
	return false;
Its not catching the event
shrinivas
Reply #218 - Jul 25th, 2014 at 1:58pm
I have attached XML with VISIO file, can u tell me why some nodes have not colored, why its showing in white color ?
XML_VDX.zip (Attachment deleted)
Reply #219 - Jul 28th, 2014 at 4:52am
Have you set the onLoad function as a body.onload handler?
Reply #220 - Jul 28th, 2014 at 5:09am
#0000CCFF is a fully transparent color, that's why the shapes are without fill in Visio (and in NetDiagram they show the diagram's background brush). Change it to #FF00CCFF instead.
shrinivas
Reply #221 - Jul 28th, 2014 at 9:17am
Stoyo wrote on Jul 28th, 2014 at 4:52am:
Following error occurred
JavaScript runtime error: Unable to get property 'addEventListener' of undefined or null reference
Reply #222 - Jul 28th, 2014 at 9:35am
If you are trying to add the handler from JavaScript, see http://stackoverflow.com/questions/10839642/addeventlistener-not-working
shrinivas
Reply #223 - Jul 28th, 2014 at 12:39pm
Stoyo wrote on Jul 28th, 2014 at 9:35am:
Thanks Its working.
shrinivas
Reply #224 - Jul 28th, 2014 at 12:42pm
I have moved MindFusion.Js file to JS folder of my project then Its giving error and if i keep in parent folder i.e my project folder then its working,
even I have added reference of JS as well as given proper path still same problem, Can you tell me solution on that?
