Hot Topic (More than 10 Replies) Zoom feature (Read 13307 times)
Re: Zoom feature
Reply #15 - Aug 14th, 2014 at 12:18pm
Replacing ZoomFactor will be a very breaking change for many customers which we don't intend to do any time soon, so please stop requesting and try to adapt to the ScaleTransform method. One way we can see to make that Xaml layout to work the same as with ZoomFactor is to set fixed size for the ScrollViewer:
scroller.Width = SystemInformation.PrimaryMonitorSize.Width;
scroller.Height = SystemInformation.PrimaryMonitorSize.Height;
Another possible way should be to override the MeasureOverride method (e.g. in MyDiagram class above) and divide the base size by current x/y scales.
Re: Zoom feature
Reply #16 - Aug 14th, 2014 at 12:41pm
Actually with that specific Xaml, setting RenderTransform instead of LayoutTransform seems to work same way as ZoomFactor without fixing ScrollViewer size, so that's a third option.
If you are still using scrolling to present multiple screens in your application as in old test project I have from you, note that you will need the new ScrollX/Y properties from MyDiagram sample above to get expected scroll positions. You might also check the DiagramDocument / DiagramPage classes added by version 3 of the control, they implement built-in support for multiple pages and you could avoid the ScrollViewer and scrolling altogether.
PDM.
Senior Member
Re: Zoom feature
Reply #17 - Aug 14th, 2014 at 2:11pm
Your solution work in the example i sent, but not in my software.
The example I sent no idea if is related to exact trouble i have, i think yes but now see no.
Nothing I test fix thiis yet.
Instead modify zoomfactor what i suggest is craate new one
ZoomAspectRatio
In that way not broke compatibility, is the same just add
ZoomAspectRatio.FactorX
ZoomAspectRatio.FactorY
About scroll after zoom, that is already solved and working with zoom, is very easy.
The page solution on versión 3.0 is good but broken compatibility with my prevous diagram and features in the software.
I continue researching, thanks for your time, but please try add that feature.
Re: Zoom feature
Reply #18 - Aug 15th, 2014 at 12:28pm
We really cannot implement non-uniform scale in short term as it would affect many controls included in wpf diagram. What we can do at this time is let you override the diagram's method that applies MeasureUnit and ZoomFactor transforms:
https://mindfusion.eu/_beta/wpfdiag32.zip
As long as you don't need support for this in misc. components like the ruler and overview, you should be able to apply your extra Y scale like this:
public class MyDiagram : Diagram
	protected override Matrix DocumentToDiagramMatrix
		get
			var m = base.DocumentToDiagramMatrix;
			m.Scale(1, 1.5);
			return m;
If that still does not work in your application, then you are probably using the non-uniform scales incorrectly in some custom-drawing or layout code, and having separate builtin properties for x/y zoom would not help you anyway.
PDM.
Senior Member
Re: Zoom feature
Reply #19 - Aug 15th, 2014 at 6:17pm
Thanks for your help! I check this soon.
Sorry for my ignorance but how apply/use this class?
« Last Edit: Aug 15th, 2014 at 7:46pm by PDM. »
Re: Zoom feature
Reply #20 - Aug 18th, 2014 at 8:13am
Replace the <diag:Diagram> element in your xaml file with a <MyDiagram> one:
<Window ...
    xmlns:my="clr-namespace:MyNamespace"
    <my:MyDiagram ...>
PDM.
Senior Member
Re: Zoom feature
Reply #21 - Aug 18th, 2014 at 10:55am
get
m.Scale(0.8, 0.8);
return m;
Faster test and work perfect like i need doing any aspect ratio.!
Sorry again, but how call the class now from C# code
MyDiagram myzoom = new MyDiagram();
myzoom ?
Thanks for your help, sorry for my ignorance.
When the beta text can be removed?
Re: Zoom feature
Reply #22 - Aug 18th, 2014 at 12:22pm
If the diagram parent derives from ContentControl, set its Content property:
scrollViewer.Content = myzoom;
If it derives from Panel, add the diagram to its Children collection:
grid.Children.Add(myzoom);
I hope the helps,
PDM.
Senior Member
Re: Zoom feature
Reply #23 - Aug 18th, 2014 at 3:45pm
I only have a mínimum trouble with scroll.
Checking what  happen.
« Last Edit: Aug 18th, 2014 at 5:59pm by PDM. »
PDM.
Senior Member
Re: Zoom feature
Reply #24 - Aug 18th, 2014 at 5:23pm
Oh Stoyo.
Apologize for large POST!
100% working, no any issue, just few more corrections from my side.
Working like a charm!!!
Thanks again, just need remove the beta TEXT.
Kiss
THANKS AGAIN!!
