Normal Topic Creation of TableNode (Read 4368 times)
Santosh
Mar 25th, 2015 at 1:44pm
Hi All,
I am new to mindfusion and need some sample code for creating TableNode using JavaScript. Help!  :-/
Re: Creation of TableNode
Reply #1 - Mar 25th, 2015 at 1:49pm
There's a SpanningCells.js example included in JsDiagram archive showing how to create tables.
Santosh
Reply #2 - Mar 25th, 2015 at 1:51pm
Got it! Thanks Stoyo  Smiley
Santosh
Reply #3 - Mar 27th, 2015 at 9:09am
I had one more query. I want to add custom attributes to table node. How to achieve that? I was able to do the same using custom node. But I need table nodes.
I need something similar for table node.
Custom Node Approach:
var Diagram = MindFusion.Diagramming.Diagram;
var Behavior = MindFusion.Diagramming.Behavior;
var AbstractionLayer = MindFusion.AbstractionLayer;
var ElementNode = function (parent)
AbstractionLayer.initializeBase(ElementNode, this, [parent]);
ElementNode.prototype =
//Defined custom attributes here
   setMyAttribute: function(value){
        this.myAttribute = value;
   getMyAttribute: function(){
        return this.myAttribute;
