Normal Topic Matching Start and End points of Links - is it possible (Read 3036 times)
AR
May 7th, 2015 at 4:56pm
When the user creates a link on one layer of the diagram, I am automatically creating one or more links on the other layer.
Is it possible to tell the links I create to start/end in the same place on the nodes as the one the user created? As illustrated in top pair of layers in attachment.
Also if I have to create multiple links is it possible to tell them to start\end near to but not on top of one another. As illustrated in the bottom pair layers in attachment.
Re: Matching Start and End points of Links - is it possible
Reply #1 - May 8th, 2015 at 8:32am
You could copy point coordinates from original link's ControlPoints to new link's ControlPoints. This should be done automatically if you use the DiagramLink(prototype, src, dest) constructor.
You can offset the cloned links using some vector math, adding normal left-hand or right-hand vector to each of their points:
import com.mindfusion.common.Vector;
void offsetPoints(DiagramLink link, float dist)
	Point2D.Float[] points = link.getControlPoints().getArray();
	int last = points.length - 1;
	Vector current = normal(points[0], points[1], dist);
	link.getControlPoints().set(0, Vector.add(current, points[0]));
	for (int i = 1; i < last; i++)
		Vector next = normal(points[i], points[i + 1], dist);
		Vector nv = Vector.add(current,  next);
		link.getControlPoints().set(i, Vector.add(nv, points[i]));
		current = next;
	link.getControlPoints().set(last, Vector.add(current, points[last]));
	link.updateFromPoints();
Vector normal(Point2D p1, Point2D p2, float len)
	Vector v = new Vector(p1, p2);
	return Vector.divide(
		Vector.left(v),
		v.length() / len);
