Normal Topic Layered layout : How to create rounded links (Read 2948 times)
Surya
Jul 10th, 2015 at 5:15am
Please explain how to create rounded links in layered layout.
The 'rounded' property does not seem to effect it.
Surya
Re: Layered layout : How to create rounded links
Reply #1 - Jul 10th, 2015 at 10:59am
Links bend only when crossing a layer. If a link is between nodes in adjacent layers, it will remain straight line. If you need to add artificial bends to make the link more curvy, you could switch to Bezier style and add control points with some offset from the straight line:
layeredLayout.Arrange(diagram);
foreach (var link in diagram.Links)
	var points = link.ControlPoints.Clone();
	// insert Bezier control points for each segment of polyline link
	for (int i = points.Count - 1; i > 0; i--)
		var segmentStart = points[i - 1];
		var segmentEnd = points[i];
		var vector = new Vector(segmentStart, segmentEnd);
		var cp1 = segmentStart + vector / 3;
		var cp2 = segmentStart + 2 * vector / 3;
		var dx = vector.X;
		if (dx == 0)
			cp1.X -= 2;
			cp2.X += 4;
		else
			cp1.X += dx / 6;
			cp2.X += dx / 6;
		points.Insert(i, cp1);
		points.Insert(i + 1, cp2);
	for (int i = 3; i < points.Count - 1; i += 4)
		var pp = points[i - 1];
		pp.X = points[i].X;
		points[i - 1] = pp;
		var pn = points[i + 1];
		pn.X = points[i].X;
		points[i + 1] = pn;
	link.Shape = LinkShape.Bezier;
	link.ControlPoints.Clear();
	link.ControlPoints.AddRange(points);
	link.UpdateFromPoints(false, true);
