Hot Topic (More than 10 Replies) CustomNode (Read 13815 times)
Silvia88
Re: CustomNode
Reply #15 - Sep 23rd, 2015 at 6:37pm
Thank you very much Smiley
Silvia88
Re: CustomNode
Reply #16 - Sep 23rd, 2015 at 7:11pm
Thank you very much, I solve the problem for the text but I have another one, I want the ellipse to be smaller, is it possible or does it depend on the text?
Re: CustomNode
Reply #17 - Sep 23rd, 2015 at 7:47pm
Pass smaller values than 3 to resize methods, but then you'll have to set even larger percents for text area. Perhaps you should not use modified text region for that as users might get confused when the outside text doesn't participate in hit-testing (if you need this kind of nodes to be selectable). Instead create a large-enough transparent node to contain all the text, and custom-draw the small circle at bottom by handling drawNode event.
Silvia88
Re: CustomNode
Reply #18 - Sep 24th, 2015 at 8:33am
Thank you very much, now it's ok  Smiley
