Normal Topic Ruler.DiagramView property is missing in VS Property Grid (Read 1899 times)
Derrick
Mar 30th, 2016 at 1:41pm
I'm evaluating MindFusion.Diagramming for WinForms Professional V6.4. The DiagramView property for the Ruler is missing in the VS Property Grid. I can set DiagramView programmatically, but after I restart, the Ruler does not display. In an older version of MindFusion.Diagramming, there is a Ruler.DiagramView property in the VS Property Grid.
Re: Ruler.DiagramView property is missing in VS Property Grid
Reply #1 - Mar 30th, 2016 at 1:57pm
What Visual Studio and .NET framework versions are you using? Also did you have an older version of the diagram control installed on same system? There might be some design-time problems if VS is still loading a cached design.dll from older version of the control.
