Normal Topic Handles not displayed (Read 2333 times)
benjamin huser
Nov 24th, 2016 at 12:49pm
Hi
I just played around with our Nodes and I wanted to add the RotationHandle:
         EnabledHandles = AdjustmentHandles.Move | AdjustmentHandles.Rotate;
         if (nodeViewModel.Resizable)
            EnabledHandles |= AdjustmentHandles.ResizeBottomRight;
The move handle is visible as soon as i select the node. But I cannot see anywhere a handle to rotate the node, am I missing something?
On the topic of the Rotation I have another question. Is it possible to specify sort of a step size. So that we don't allow to set any rotation angle but just the ones that are dividible by 90 (e.g.: 90/180/270/0).
Regards
benjamin huser
Re: Handles not displayed
Reply #1 - Nov 24th, 2016 at 1:32pm
Hi
ok I just figured out that it depends as well on the HandlesStyle that is set. So I managed now to rotate the control via tha handle.
But my second question still remains.
Reply #2 - Nov 24th, 2016 at 2:05pm
There's no rotation step size property. You could align to nearest multiple of 90 from NodeModified handler -
if (e.AdjustmentHandle == AdjustmentHandles.Rotate)
	e.Node.RotationAngle = (int) e.Node.RotationAngle / 90 * 90;
benjamin huser
Reply #3 - Nov 24th, 2016 at 2:47pm
Hi Slavcho
thanks for the tip, that solved my issue Smiley
