Normal Topic AllowLinksRepeat not working (Read 1588 times)
PauliusP
Mar 3rd, 2017 at 3:26pm
I need to implement functionality that links between nodes (shapenode) won't repeat in my diagram. Available only 1 link from one node to another.
I found out that there is the exact method: "AllowLinksRepeat", that would solve the problem.
But it didn't work when I tried to use it like this:
Code (HTML)
<Diagram RouteLinks="true" AllowLinksRepeat="false" GridStyle="Lines" AlignToGrid="True" ShowGrid="True" GridColor="#1B000000" GridSizeY="10" GridSizeX="10"
                                AdjustmentHandlesSize="8" LinkCrossings="Arcs" HitTestPriority="ZOrder" AllowUnconnectedLinks="false" AutoResize="None">
                            </Diagram>
Re: AllowLinksRepeat not working
Reply #1 - Mar 3rd, 2017 at 4:55pm
The AllowLinksRepeat property is not available yet in JavaScript diagram library. At this time you could prevent repeated links from linkCreating validation event -
function onLinkCreating(sender, args)
	var link = args.getLink();
	if (!link.targetConnection)
		return;
	var origin = link.getOrigin();
	var dest = link.targetConnection.node;
	args.setCancel(
		linkExists(origin, dest));
function linkExists(from, to)
	var links = [];
	from.getAllOutgoingLinks(links);
	for (var l = 0; l < links.length; l++)
		if (links[l].getDestination() == to)
			return true;
	return false;
