Normal Topic Undo/redo (Read 4104 times)
fractal07
Undo/redo
Jul 25th, 2017 at 1:49pm
I'm still working hard on an application using Scheduling (WinForms/C#/VS2015) and I sincerely congratulate you, good job! Components are great and bugless!
May be you could help me... I store all my appointments in database, I manage many events to update DB (ItemClick, ItemModified,...) but I do not find how to catch the undo/redo.
To be clear: undo/redo is easy to use with calendar.Schedule.Undo() but I need to add database updates !
By the way, I have the same issue when I remove an appointment using DELETE key ; I obviously catch the key but I do not succeed in managing the remove behaviour...
Re: Undo/redo
Reply #1 - Jul 26th, 2017 at 7:05am
You can handle the ActionUndone and ActionRedone events of the Schedule class to get notified when an action is undone or redone respectively. To get notified when an item is deleted, use the Calendar.ItemDeleted event.
fractal07
Re: Undo/redo
Reply #2 - Jul 26th, 2017 at 10:14am
Thank you meppy for your perfect quick reply!
