Normal Topic How do I connect twice from DiagramNode A to DiagramNode B? (Read 1495 times)
chowy
Jul 28th, 2017 at 9:56am
Mindfusion the diagramlink is not allowed to connect with the same source diagramNode and the same target diagramNode. Can I close this restriction? I need to connect from DiagramNode A to the DiagramNode B twice through a different anchor point.
Re: How do I connect twice from DiagramNode A to DiagramNode B?
Reply #1 - Jul 28th, 2017 at 11:07am
It's allowed by default. Check if you haven't disabled the AllowLinksRepeat property, or aren't restricting such links from LinkCreating validation event.
chowy
Reply #2 - Jul 31st, 2017 at 2:54am
Slavcho wrote on Jul 28th, 2017 at 11:07am:
Ok,Thanks!!
