Normal Topic Node Text Very Small When Dragged From Node View List (Read 1998 times)
alukes
Aug 30th, 2017 at 3:59am
JavaScript Diagramming Version 3.0.1 Flowcharter example
I drag a shape from the node list view and it appears styled like the other nodes already on the chart. If I add text it is extremely small and I try to make it larger with the font size control, but it has no effect. In fact no font control, such as bold, italic or underline has any effect.
I tried making my own node list with text in each node and the text remains very small.
What should I try?
Re: Node Text Very Small When Dragged From Node View List
Reply #1 - Aug 30th, 2017 at 4:58am
Call node.setFont(null) from onNodeCreated handler. It seems NodeListView sets it to a small font for the nodes it hosts, and the font controls in Flowcharter example use Style objects, which have lower priority than Font.
alukes
Reply #2 - Aug 31st, 2017 at 12:51pm
Thank took care of my problem.
Thanks!
