Normal Topic Not able to use class for Image (Read 2569 times)
Shafi
Apr 26th, 2018 at 3:46pm
In css have added following class
    .ibs-icons-big-error {
        background-image: url('../../../assets/img/cmdelementnew24.svg');
When add image inside using this class then it not appearing
                const icon = new MindFusion.Drawing.Image(config.actionImageRect);
                icon.image.className  = "ibs-icons-big-error";
                icon.image.name = "Action";
                icon.image.addEventListener("load", function () {
                    icon.loaded = true;
                    item.invalidate();
                icon.loaded = true;
                item.getGraphicsContent().push(icon);
Lyubo
MindFusion team
Re: Not able to use class for Image
Reply #1 - Apr 27th, 2018 at 5:42am
The image property of the MindFusion.Drawing.Image class is actually an Image DOM element, so you need to set its src attribute.
Code (Javascript)
icon.image.src  = "pathToImage";
Lyubo
Shafi
Reply #2 - Apr 27th, 2018 at 8:11am
I would like to apply image path using class instead of direct path.
Why class not get applied on image?
Reply #3 - Apr 27th, 2018 at 8:52am
You won't be able to. The diagram is rendered using Canvas API, this image is not part of the DOM tree and not styled by the browser.
