Normal Topic How to use the print preview with paper settings etc. (Read 2524 times)
Dirk Woelfel
Aug 26th, 2018 at 6:44pm
I would like to use the print preview. Unfortunately I can't find a way to edit the paper size and orientation in the preview.
Is there a possibility of an extended print preview in which the user can possibly make these specifications?
Thank you very much,
Dirk
Lyubo
MindFusion team
Re: How to use the print preview with paper settings etc.
Reply #1 - Aug 27th, 2018 at 12:05pm
You can use the PrintPreviewEx method on DiagramView. It opens a form which also has scaling and orientation buttons. You can see it in the Demo sample provided with the Diagramming package.
To allow users to edit the size of the page, you can use the standard .NET PageSetupDialog (it offers orientation change too), and use the setting from there with the default or extended print preview dialog.
PageSetupDialog pageSetup = new PageSetupDialog();
pageSetup.Document = new System.Drawing.Printing.PrintDocument();
pageSetup.Document.DocumentName =  "Diagram";
// Show the dialog to allow users to select page size / orientation.
pageSetup.ShowDialog(this);
// Show the extended print preview dialog with the diagram object.
_diagramView.PrintPreviewEx(pageSetup.Document);
Lyubo
Dirk Woelfel
Reply #2 - Sep 10th, 2018 at 3:56pm
Thanks a lot! It works.
Dirk
