Page Index Toggle Pages: 1 ... 6 7 [8] 9 10  Send TopicPrint
Very Hot Topic (More than 25 Replies) Html Node in Diagram ! (Read 61794 times)
Lyubo
MindFusion team
Re: Html Node in Diagram !
Reply #105 - May 4th, 2020 at 1:43pm
Ah yes, missed out one bit, in your setCompositeNodeBorderColor method, you need to call the setters of the shape properties - namely setStrokeThickness and setPen.
      var background = node.getComponent("OutlineShape") as any;
      if (background) {
        background.setStrokeThickness(this.strokeThickness);
        background.setPen(borderColor);
Lyubo
Kannan Thirumal
Senior Member
I Love Mind Fusion Diagram
Reply #106 - May 4th, 2020 at 2:02pm
Hi Lyubo,
After changing those fields to set methods, it works fine but the white border (because of shadow) doesn't look good. Is there any other option?
Kannan
Lyubo
MindFusion team
Reply #107 - May 4th, 2020 at 2:22pm
Both the shadow and the stroke thickness will respect the node's dimensions, which is the general use case.
If in your case the white stroke doesn't look good, and you don't want to go back to custom drawing the border like it was before, you could set a margin to the shape of nodes which aren't supposed to have a border, so the shadow shrinks too; and removing it when there is selection. That approach can be seen in the attached image.
Lyubo
Kannan Thirumal
Senior Member
Reply #108 - May 4th, 2020 at 4:06pm
Hi Lyubo,
I did this workaround to fix this,
  private setCompositeNodeBorderColor(node: CompositeNode, borderColor: string, isSelection: boolean) {
    if (background) {
      var diagramElement = node.getTag().DataObject as DiagramElement;
      var borderColor2 = (isSelection || !diagramElement.isShadowElement) ? borderColor : "Transparent";
      background.setPen(borderColor2);
      if (diagramElement.isShadowElement) {
        if (isSelection) {
          node.setBounds(new Rect(diagramElement.x, diagramElement.y, diagramElement.width + 6, diagramElement.height + 6));
          var mainImageComponent = node.getComponent("MainImage") as any;
          mainImageComponent.margin.left = 3;
          mainImageComponent.margin.top = 3;
          mainImageComponent.margin.right = 3;
          mainImageComponent.margin.bottom = 3;
        else {
          node.setBounds(new Rect(diagramElement.x + 3, diagramElement.y + 3, diagramElement.width + 0, diagramElement.height + 0));
          mainImageComponent.margin.left = 0;
          mainImageComponent.margin.top = 0;
          mainImageComponent.margin.right = 0;
          mainImageComponent.margin.bottom = 0;
    node.invalidate();
But still I could see a space in between the image and border when I do zoom.
Kannan
Kannan Thirumal
Senior Member
Reply #109 - May 9th, 2020 at 12:57pm
In our app, we show extra (small) icons in the diagram node. Mostly this will be left side/right side of the node. For Rectangle shape, it works fine. But for the Decision shaped node, I'm facing an issue. Since we set shape for the whole node, the extra icons are not showing properly. It works fine for same data in silverlight app.
I think it is better if we set the shape for the main image only. Is there any way to fix this?
Kannan
Lyubo
MindFusion team
Reply #110 - May 11th, 2020 at 5:49am
When using the isOutline property of the Shape component, all the contents of the template will clip to the shape's outline. For a following release, we can add a property that let's you turn off the clip.
Lyubo
MindFusion
Kannan Thirumal
Senior Member
Reply #111 - May 11th, 2020 at 6:16am
Hi Lyubo,
Thank you! That will be a great help !
Kannan
Kannan Thirumal
Senior Member
Reply #112 - Jun 15th, 2020 at 5:17pm
Hi Lyubo,
     May I know when this feature will be available? Looking forward for that.
Kannan
Lyubo wrote on May 11th, 2020 at 5:49am:
Lyubo
MindFusion
Kannan Thirumal
Senior Member
Reply #113 - Jul 29th, 2020 at 5:29am
     Looking forward for this release.
Kannan
Lyubo
MindFusion
Lyubo
MindFusion team
Reply #114 - Aug 16th, 2020 at 6:31am
This change is included in the latest JavaScript suite here; a standalone version is also published to npm: https://www.npmjs.com/package/diagram-library.
There's a new clipToOutline property added to CompositeNode that lets you specify whether contents of the node's template will clip to a shape outline or not.
Lyubo
MindFusion
Kannan Thirumal
Senior Member
Reply #115 - Aug 18th, 2020 at 8:58am
Hi Lyubo,
Thank you, I'll try this.
Kannan
Kannan Thirumal
Senior Member
Reply #116 - Nov 2nd, 2020 at 6:47am
I've a hierarchical diagram of composite nodes. In each node the expander icon is not shown. If I construct the diagram with shape nodes, the expander icon is showing up in the right side of the node. Please check the attached images.
Kannan
Lyubo
MindFusion team
Reply #117 - Nov 2nd, 2020 at 7:16am
Calling setExpandable(true) on the nodes, should enable the expander manipulator.
Lyubo
MindFusion
Kannan Thirumal
Senior Member
Reply #118 - Nov 2nd, 2020 at 7:29am
Hi Lyubo,
I tried this earlier but icon is still not showing. Please check the uploaded sample in the below link,
https://drive.google.com/file/d/1ZMNJCweU3cotRokOLEMb5ndAQoXbsZRX/view?usp=shari
ng
Kannan
Lyubo
MindFusion team
Reply #119 - Nov 2nd, 2020 at 7:55am
Can you provide a link that doesn't require google id?
Also, it appears this particular feature was added in the latest release. Try updating your packages and try if that fixes it for you.
Lyubo
