Normal Topic Clear button not working (Read 7064 times)
ErikJ
May 7th, 2019 at 1:13pm
I am using Winforms.
I have added the extended Clear button to my layout.  When pressing, I just see a lower case 'a' appear in the focused entry box.  No clear or deletion of text happens.
I see in the Keyboard Layout Creator that the Clear button contains the 'a' key with Control lock enabled and the Delete key.  But looking in the output xml, I do not see any indication of the ctrl lock option being set.  Is there something I am missing that enables the Ctrl+A feature to work properly?
Re: Clear button not working
Reply #1 - May 8th, 2019 at 1:55pm
This sets a ControlLock property marked as [Obsolete] and [XmlIgnore] in the original keyboard code we acquired from FreezePro Software some years ago. You can edit the Clear key as in image below to still get a Ctrl+A,Del sequence -
We'll decide what to do with that ControlLock for next release.
ErikJ
Reply #2 - May 8th, 2019 at 2:10pm
Thanks that worked for me!
